camera case exhitbiting sticky substance
My camera wasn't shown i have a PENTA W90 been in heated storage for 9 years the plastics exhibiting a stickiness is there any way to lean this?
Hello! Unfortunately this is the end-of-life state for a lot of rubberized electronics, the rubber coating just turns back into goop after long enough, especially when heat and sunlight are involved. The best method i've found for removing it without damaging the plastic underneath is a LOT of isopropyl/rubbing alcohol, it'll take a lot of effort but it should get all of that gross stickyness off for good! :) @larrylewand4914
このアンサーは役に立ちましたか?
I had a similar problem with electronics and found an answer that seems to work well.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 113
