Can I charge my JBL Boombox in my car?
What type of cable do I need to charge my JBL Boombox 1 in my car, and what is the required voltage for charging? Will it damage my Boombox? What are the risks?
@gigglinggrandpa yes you can, if you have the proper converter. Your boombox needs 19V to charge and luckily those DC car adapters are readily available. Check on places like this as an example onle. Do an online search and chose a vendor that appeals to you.
このアンサーは役に立ちましたか?
I have found that on my boombox 2 you can charge it on 12v just takes a little longer but it does worm so I can take my usbc power bank that outputs 12v and charge my boombox with it which it cool and will extend the run time of it
過去 24時間: 0
過去 7 日: 6
過去 30 日: 34
今までの合計 280
