price estimates on repair
how much to change out the charger port and repair beats
Here's a guide that generally shows you the process to repair the charging port on Beats Solo.
Note that this guide is for a Beats Solo 3, and your exact model may differ. However, the cost of the part itself is about $10 based on an online search. You will also need supplies for the disassembly as detailed in the guide. These supplies come out to about $60 if purchased through iFixit.
If you decide to get the headphones repaired as opposed to pursuing a DIY repair your rates will vary based on your location and the labor charge from your technician.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 12
過去 30 日: 36
今までの合計 2,566
1件のコメント
add which country you are from as there are people from all over the world here
daniel さんによる
