メインコンテンツにスキップ
Announced July 05, 2022 Released July 13, 2022
8回答 すべてを表示
Sim Card does not work on rog phone 6.
So i got a new phone and i went to algeria some days after, my mom gave me a Sim card and it didnt work on the phone, i tried using it on another phone and it worked, so the problem is the phone itself.
(The sim card is from Ooredoo brand)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
What country did you buy this phone in?
Since you mention buying the phone before going to Algeria, I am assuming that you bought the phone in a different country.
Algeria only uses a select few wireless signal bands for their devices, so sim cards sold for that network will be keyed to only activate on those bands. So, for example, if you bought your phone in the USA, the phone will have antennas that can pick up 4G bands such as B2, B4, B12, etc. But in Algeria, the ONLY 4G band that is has is the B3 band. A phone bought in the USA will not have the right antenna to pick up a signal in Algeria. At all.
You can use this website to check the bands available in the country you bought it from: https://www.kimovil.com/en/frequency-che...
It is currently set to Algeria, so you can see the bands there. Change the country to where you bought the phone. If it does not have the same bands, it will be impossible to pick up a signal in Algeria with a phone that was designed to pick up a signal in it's origin country.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Devious さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 26
今までの合計 276
