Is there a newer replacement MB that would fit this Acer Aspire 7741Z?
I would like to upgrade this computer. Is there a newer replacement MB that would fit this Acer Aspire 7741Z-4815?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Not that I know of. You may be able to upgrade the CPU. Which CPU do you currently have?
Your best bet would be to upgrade the RAM to 2 (i.e. identical pair) x 4GB 204p PC3-10600 DDR3-1333 SODIMM for a total of 8GB.
The hard drive can be upgraded to an SSD drive.
You could also upgrade to Windows 10 which will provide most of the drivers needed.
このアンサーは役に立ちましたか?
Thank you for your help. I like this laptop and it would be fun to upgrade it as much as I can. $ is not a real issue.
ASUS Aspire Model # MS2309, 7741Z-4815, Intel Pentium CPU P6100@2.00Ghz, 4GB Ram, 64-bit.
Would the SSD be SATA?
Hi @bjhawk
Yes SATA SSD
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 69
