V7 allergy shuts off when I put it on max setting.
My V7 allergy shuts off when I put it on max setting. I have cleaned it very well and put in new filters.
There is most likely a battery problem. You can try fully charging the battery and see if that resolves the issue. If not, you should purchase a replacement battery. If the issue persists even after replacing the battery, you will need a replacement main body.
I hope this helps!
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 8
今までの合計 179
