メインコンテンツにスキップ
Repair and Disassembly guide for the 2020 ASUS G15 G512LI, A laptop produced by Asus for budget/light gaming.
29回答 すべてを表示
Won’t power on
My pc won’t turn on I got it last year and left it in my closet because I try turn it on but the power button won’t show up and there supposed to be a light on the charger but it doesn’t show it is it because my charger connected maybe out of use because I did get it a year ago
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
@erichills54272 your charger should not quit working just because you haven't used it. Your laptops battery may have. It may have been discharged below it's threshold to accept a charge. Consider replacing that. Check your charger to make sure it outputs the proper voltage. Check the charging cable for any send or broken connectors. Check the charging port for any debris, broken or bend pin. You can always clean it with a few drops of isopropyl alcohol and a few puffs of compressed air. If it still does not come on, time to check it on the inside. Since you are probably going to replace the battery, use that opportunity to double check the DC in jack for proper voltage on the board side.
Use something like this video as your guide.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Look for any LED lights or indicators on your PC that should normally illuminate when it's powered on. If you don't see any lights or hear any sounds, it could indicate a more significant hardware problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eric Hills さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 14
今までの合計 259
