メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
Strange screen incompatibility issue
Hi, I’ve run into a weird problem with a screen replacement for an iPhone 8 Plus, the factory value is C3f for the screen, I bought a C3f screen refurbished replacement, but when installed it has no touch, the screen works on other 8 plus phones, I check the serial on the old screen, and it starts with C190.. I have no idea what that is, I can’t find any info on it, but it’s the only one that works with touch, even though it doesn’t match the factory value in 3utools and JCID
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
where did you buy the screen from? Was it like an OEM refurbished screen?
さんによる
Yes, the new screen works on other iPhones without issue, but this one 8 plus, refuses to work with any screen but the one that broke, and that screen isn’t the original, the phone is gold and the screen was black..
さんによる
コメントを追加
1 件の回答
ベストアンサー
After speaking to a screen supplier and repairer, apparently some iPhone 8 Plus’s get used to aftermarket screens and will only accept an aftermarket screen as compatible after only using aftermarket screens for a long time.. So I will try fitting a standard aftermarket screen and see if it works.. that’s a strange issue, so now I wonder if anyone knows how to gain compatibility back to the factory value, True Tone repair through JCID did not fix it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Confirmed, tried several aftermarket screens all touch working, tried a couple more broken refurbs and originals, touch not working. For some reason this 8 plus only works with aftermarket screen replacements.
さんによる
コメントを追加
回答を追加する
Becklyoh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 215
