Hoverboard not turning on
Have green lights on charger till I plug into hoverboard and lights go out can anyone help me 🙏
Could be the battery. If you don’t charge it very often then the battery can lose charge and if it drops below 30 volts the bms won’t accept a charge. Will probably need a new battery. Open it up and check the battery voltage with a multimeter.
このアンサーは役に立ちましたか?
Battery capacity is 25.2v, tested capacity is 24.7
You need a new battery as it's gone below voltage I'm afraid.
Thanks for that, will look for new battery 🤔👍
Do you know best place to get one from???
Battery is charged and ,each time I press the start button it kills the Battery of 8 volts in one jolt and won't turn on , with no signs of damage on the mother board or any components withing the unit .
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 14
過去 30 日: 62
今までの合計 334
