メインコンテンツにスキップ
Repair information, service guides, and troubleshooting help for refrigerators manufactured by Frigidaire.
86回答 すべてを表示
Frigidaire Gallery FGHC2331PFAAb CONSTANT annoying shrill sound
I rent an apartment with a Frigidaire Gallery FGHC2331PFAA. It constantly makes a high pitched shrill/ringing noise. It can be heard in the bathroom and even upstairs sometimes. It started a couple weeks ago. I have vacuumed the back out as well as I could but it only helped a little. It’s either the condenser fan or compressor. The sound is driving me and my partner crazy. The living room and kitchen are one, so it really disrupts activity. Can someone please assist? Please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @willa78
It could also be the evaporator fan (supplier link only to show where it is located)
With most refrigerators, the evap fan runs when the compressor is running and it will stop when the door is opened (either door) and start again when the door is closed. It will also stop when the compressor stops.
The condenser fan can run at any time whether the doors are open or not or even if the compressor has just stopped, as is it temperature controlled
If the noise stops when a door is opened or when the compressor is stopped due to set temp reached or if a defrost cycle is occurring then the evap fan may be the cause.
If it is the fan search online for 241509402 to find suppliers that suit you best.
If the fan is covered in ice when you check it, then there's a defrost problem.
Access to the fan is through the door at the front of the refrigerator. You have to remove a panel on the inside wall at the back of the compartment.
Be safety aware and disconnect the power when inspecting the fan
241509402 - Electrolux Refrigerator Evaporator Fan Motorの画像
製品
$117.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Will さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 31
今までの合計 187
