メインコンテンツにスキップ
Repair guides and troubleshooting for the Whirlpool Quiet Partner II insulated dishwasher.
Whirlpool Dishwasher melted plastic on heating element. HELP!
My dishwasher is actually a Whirlpool Goldseries . A knife with a plastic handle accidentally melted on my heating element. It is stuck there now. How can I remove it without damaging the heating element? Also how do I know which plug is which under the sink? Disposal and Dishwasher. Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
@polly88412 get yourself an inexpensive heat gun and apply that heat to the plastic on the heating element. You won't melt the element but just get it hot enough so you can remove the molten plastic.
このアンサーは役に立ちましたか?
スコア 2
8 件のコメント:
Thank you oldturkey03. Do you think a blow dryer would do the same? I have a blow dryer I could try...
さんによる
@polly88412 it won't get hot enough to melt the plastic.
さんによる
okay. I will go get a heat gun tomorrow. Thank you.
さんによる
One more question... ( yes I have many) I am 81 years and a widow so I am learning how to do all of these things now......do I put the heat gun right on the plastic or just apply it to the heating element to heat that up... or?
Thanks.
さんによる
@polly88412
I would apply it to the plastic (not touching) as it will absorb the heat and you can then pull it off as it softens.
If you apply it to the heater element, being metal, it will disperse the heat as most probably it has a bigger surface area
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Polly さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 37
今までの合計 1,079
