メインコンテンツにスキップ
Wi-Fi, GSMとCDMA モデルのiPad第二世代です。あるモデルはiPad3発売前に改良されたものがあります。修理は困難で、熱で温めてこじ開ける作業が必須です。
729回答 すべてを表示
A1397 Looking for NAND Flash Memory Chip to Physically Destroy
Mine is the A1397. And I am just trying to physically destroy the data before i give it to a recycling center. So I don't need to be careful with it. However, after doing some research online and asking chatGPT it told me that only the NAND flash memory chip holds the data and I am having trouble identifying where this component is. I am just trying to find the part that holds this NAND flash memory chip and physically destroy it with a hammer or something, so no one can access the data. Any suggestions? I attached a picture where one component is on the left, and the other component is on the right. In which component or piece is the data located or stored? Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Right side, under the big metal shield.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Cool, thank you so much. That narrows it down. Do you know which part of the big metal shield? There seems to be 3 segments to it. I am assuming under the big metal shield is the logic board and the NAND flash chip is embedded into it? Thanks again.
さんによる
@tonythebruin all marked in the tear down page, seems to be under the shield next to the battery connector.
iPad 2 Wi-Fi EMC 2415 Teardown
さんによる
Got it, thank you so much. That teardown page helps!
さんによる
コメントを追加
回答を追加する
Anthony Liu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 17
今までの合計 136
