メインコンテンツにスキップ
Release Date: January 5, 2022.
3回答 すべてを表示
meu pc apos mudanca pasta termica nao arranca
mudei a massa termica do pc removendo a bateria e desde enetao nao foncionou mais. o que podera ser?
Google translate:
my pc after changing thermal paste does not start
I changed the thermal mass of the pc by removing the battery and since then it has not worked anymore. what could it be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@filipemoutinho since it worked before and stopped working after you changed the thermal paste, make sure that everything is properly connected. Double check each and every connector. Make sure that they are properly seated. Use a multimeter and measure to see if your computer gets power from the DC in Jack.
Translation
@filipemoutinho uma vez que funcionava antes e deixou de funcionar depois de mudares a pasta térmica, certifica-te de que tudo está corretamente ligado. Verifique novamente cada um dos conectores. Certifique-se de que estão corretamente encaixados. Usa um multímetro e mede se o teu computador recebe energia do conetor DC in.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Filipe Moutinho さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 58
