メインコンテンツにスキップ
Guides and repair information for dryers produced by Bosch, a German engineering and technology company.
5回答 すべてを表示
What sensor can cause F09 fault? Machine stops, clothes are still wet.
During the cycle my machine stops running displaying F09 fault. The cloths in the machine are still wet. I can restart the dryers, but sometimes it stops again, sometimes it keeps running till the end. When the machine complete the full cycle, sometime cloths are still not dry however the sensor should measure this. How can I find if the humidity sensor is failing or the over temp sensor is failing or......
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Doing a search indicates that your dryer temperature sensor has failed. "NTC" broke. Ntc is a thermistor. You should be able to replace it.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hey thanks,
I will find how to replace the the NTC, This will be probably the root cause.
I will leave a message when it is replaced.
さんによる
コメントを追加
回答を追加する
Hans dusar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 107
