メインコンテンツにスキップ
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
What is the high ram acer aspire one zg5 support
what is the high ram acer aspire one zg5 support
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Here is a link to the service manual for your computer. On page 22 it states the maximum ram is 2 GB.
http://tim.id.au/laptops/acer/aspire%20o...
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
最も参考になった回答
In practise, ZG5 can only accept 1,5 gigabytes. This is due to following:
  • the chipset limitation is 2 GB
  • there is 512 MB (0,5 GB) RAM soldered onboard
  • there is only one memory slot
So, if you add a memory stick of 256 MB (0,25 GB), 512 MB (0,5GB) or 1 GB you'll be fine as you don't exceed the chipset limitation. 1,5 GB memory sticks don't exist. If you add a stick of 2 GB (or more), you'll exceed the chipset limitation and your ZG5 won't boot.
There are rumors of physically removing the original onboard RAM and then adding a 2 GB stick but I don't personally know anyone having done that. Anyway, I wouldn't recommend it, it would require some skills with soldering iron and such. I also have a vague memory of someone talking about newer ZG5 units having 0 or 1 GB onboard memory, so giving a possibility to reach the 2 GB limit, but I only have met older ZG5's with 512 MB onboard.
このアンサーは役に立ちましたか?
スコア 10
コメントを追加
So the solution is to through out the al ready memory and put in thew only slot in new 2gb. Isn it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
LIZ さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 23
今までの合計 17,301
