メインコンテンツにスキップ
Repair information for the Asus VivoBook Flip 14. Model numbers: TP412U/TP412UA/TP412FA. Released in 2018.
My chargers wire near the pin is sparking?
It started to do it today and I dont know what to do as I can not buy a new one because it is expensive because I live in KSA and this charger was bought last year as the original one and the first replacement broke.Laptop is Asus Vivobook Flip 14 tp412fa.
Edit:After looking at the charger wire it is not fixable so I have to buy a new one.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hi @roofy96701,
Post an image in your question showing where it is sparking as that will help to know what may be able to be done.
Here's how on ifixit iFixitでの質問に画像を追加する方法
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@roofy96701 "Edit:After looking at the charger wire it is not fixable so I have to buy a new one" not really. You could get a replacement barrel connector and solder that on the cable, after you remove the old one. It'll be a lot cheaper than a new charger and keeps you from throwing a charger out.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi @roofy96701,
To add, you need a DC barrel plug with the following specs so it fits properly into the laptop as they are not all the same size
4.00mm outer diameter
1.35mm inner diameter
alternatively you can buy the complete cable open up the charger case and connect the new cable to the same connections in the charger as the old cable was.
Just remember to get the polarity correct.
The inner plug conductor is +ve and the outer is -ve (usually red wire for +ve and black wire for -ve, but it may not be these colours, so use an Ohmmeter to verify if they're not).
DO NOT REVERSE THEM as you could damage the motherboard in the laptop.
さんによる
コメントを追加
回答を追加する
Roofy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 72
