メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2022年10月に発売されたGoogleのスマートフォン「Pixel 7 Pro」の修理・分解情報です。モデル番号はGP4BCとGE2AEで識別できます。
I replaced my screen and now the phone seems to get stuck bootlooping?
I just replaced my screen as per the instructions and now it seems to be stuck in a boot loop. Screen comes on show "google' in color on the screen and them goes black and repeats. Not sure how to get it to run the calibration process.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Verify ifixit did not send you a pixel 6 pro screen like they did to me!
さんによる
The new problem screen has date code 20210305. The old scrren (also from IFIXIT in September) has date code 20210805.
さんによる
コメントを追加
3件の回答
最も参考になった回答
I am having the same issue and it seems to be something in the screen. If I put the old screen back in the phone immediately boots.
here is a video of the problem.. https://youtu.be/PwLwJ0E-DK0
UPDATE: Turns out they packaged Pixel 6 Pro screens in their Pixel 7 Pro kits! The two screens are extremely similar and it appears the hardware is technically compatible but the software is not.
このアンサーは役に立ちましたか?
スコア 2
12 件のコメント:
I am having the exact same issue. No response from support on this yet.
さんによる
I bought the replacement screen on Oct 9, 2023 for my google pixel 7 pro. And I have absolutely the same problem - old screen works fine, replacement screen only shows Google logo
さんによる
@konst83434 @jptaormina they likely sent you a pixel 6 Pro Screen! I took my phone and the ifixit screens to a ubreakifix and they confirmed the issue. I'm sure ifixit will make it right. It's obviously an easy mistake to make.
さんによる
I recorded video of the whole situation. I'll have a video posted soon.
さんによる
7件以上のコメントを表示
コメントを追加
It sounds like either your replacement screen is faulty or that something wasn't done correctly during the replacement procedure. There could be many reasons for a device to bootloop, however, since this occured upon a screen change, it's most likely hardware related. It's mostly about power when we're talking about hardware-related bootlooping, and the phone not being able to draw the correct amount of current from the battery for it to function normally.
These could be some of the causes of this issue:
  • Something was incorrectly done during the repair, such as not properly connecting a cable.
  • Something was damaged during the repair, such as unintentionally stabbing a component on the motherboard.
  • The replacement screen is faulty.
I don't know where you bought the replacement screen from, but as long as it's not a cheap knockoff, it shouldn't be the issue on the first hand. Here's a link to a replacement screen from iFixit.
Troubleshooting
  • Turn off the phone, let it charge for a bit, and then try to turn it on again.
  • Open the phone up, take a close look and make sure that all the cables are properly connected and nothing looks broken.
  • Try the old display again and see if that works. If it does, you might be dealing with a faulty replacement screen. If that's the case, then contact the seller you got it from and ask if you can get a refund or a new display
  • Read the guide again and make sure that you've done everything correctly. Even errors that seem small could result in the repair not being successful. Also remember to read the description and other notes, as they might come in hand.
Replace a front glass digitizer screen for a Google Pixel 7 Pro smartphone. Features a 6.7 inch 1440 x 3120 pixel AMOLED Display.の画像
製品
Google Pixel 7 Pro Screen - Genuine
$212.99
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Nope they sent the wrong screen!
さんによる
I saw that, good thing you solved it! :-)
さんによる
コメントを追加
@amjtech Thank you so much for posting your answer and adding your video! I've run into the exact same issue and I would not have realized why had you not written that post.
I do have a question though: My phone is currently stuck in a boot loop and I can't figure out how to turn it off safely. Should I just let it loop until the battery dies?
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
if you can put the old screen on the phone and you can see anything on the old screen you can use an OTG adapter if you have one and a mouse to turn the phone off.. if you already glued it back together yea just let it go dead
さんによる
@amjtech Unfortunately the old screen was so badly shattered it did not survive disassembly.
さんによる
Hold volume down and power button for 30 sec until recovery screen come up. Push volume up button then select power off.
さんによる
@azrockrunner Thanks! That worked!
さんによる
@azrockrunner I didn't think about that
さんによる
コメントを追加
回答を追加する
Andrew Ewing さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 62
今までの合計 2,339
