メインコンテンツにスキップ
Google Pixel4aの修理情報。 2020年8月20日発売。モデル番号:GA02099-US。
57回答 すべてを表示
How to turn phone off with broken screen and digitizer.
I have a screen repair kit coming from ifixit and want to be sure the phone is off before I open it up. Pressing and holding the power button seems to just force the phone to restart, not turn off. I know it's on as it dings when I connect it to a computer. I assume it's stuck on the lock screen as you can't use the fingerprint scanner on initial log. Anyone with a 4a able to try this out and let me know what works? Thanks in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
usually you hold down the power button, then a confirmation promt comes up, when you need the touch screen .
So instead of that just hold down the power button until the phone powers down, even if something comes up on the screen, just don't release the power button.
Now lets assume that the screen is not displaying anything.
In that case too hold down the powet button. In this case the problem is that you won't know if the phoe is off or not unless your phone vibrates while powering off.
So just hold the button for 15–20 sec. It should work.
  • Once the phone is turned off, you can remove the battery (if it's removable) or leave it as is until you can have the screen repaired or replaced.
Alternatively, if your phone has a non-removable battery, you can wait for the battery to run out and the phone to turn off on its own. This may take a few hours or more, depending on how much charge your phone had when the screen broke
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I had the same thought and have tried that a few times. But every time, if I plug the phone in to a computer, it still dings. Seems strange.
さんによる
コメントを追加
回答を追加する
Allan Guilmart さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 25
過去 30 日: 117
今までの合計 643
