Need to bypass lid lock Whirlpool cabrio WTW8040DW4
Need to bypass lid lock, looks like pins 1,4,5, and7 should all connect am I correct?
The lid lock assembly part number is W10810403 and the lid lock pins are 1, 4, 5, and 7.
このアンサーは役に立ちましたか?
I tied 1,4,5,7 together and it worked, but only once, looks like I need to check the connects on the main controller board, j-6, and try again, I'll get back with you thanks, Greg Winchester
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 167
1件のコメント
I'd like to add this to to holmy previous answere, I had to hold the blue wire , pin 4, to pins 1,5, and 7 for 30 seconds to make the machine think it was unlocked, and then remove it to make the machine think it was locked. I'm not completely sure if that as actually necessary or not.
Gregory Winchester さんによる
