メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Marshall Stockwell Bluetooth speaker
Can I use my Marshall Stockwell without the battery?
The battery on my Marshall Stockwell does not retain charge anymore. I removed it and i will refurbished it with a company that dedicates to this. Can i use it without the battery in the meantime?
Update (07/02/23)
After posting this question here, I contacted Marshall through their chat support.
They told me that removing the battery and using the speaker connected to the power supply charger would not cause any damage.
I decided to give it a try, and I'm happy to report that it works perfectly.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
How do you connect the charger to the speaker directly? Is it simply an usb connection?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Check first your power supply if it still working.
  • Remove connecting terminal of your battery and check the positive and negative terminal wires if there's still voltage output. I yes, may your battery was already damaged (Replace it). If no voltage output or has a lower voltage output, replace your power supply battery charger.
  • If you want to use it without the battery anymore, you can use a power supply that has the same voltage/current rating to your charger/battery. Connect the power supply directly to the battery terminals after removing the battery.
I hope it can help.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks for your reply, James!
さんによる
コメントを追加
回答を追加する
Fokka85 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 35
今までの合計 1,570
