メインコンテンツにスキップ
ロジクールのワイヤレスマウス「MX Master」の修理・分解情報です。2015年に発売され、モデル番号M-R0052、810-004457、910-004337、910-004955、910-005441、910-005527、または910-005228で識別されます。
The left button is stuck on something inside the mouse
The left mouse button was lifted up by accident. I pushed it back down, but now it seems to be caught on something inside the mouse. The button is raised and takes more effort and travels more to make a successful click.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi Gilded,
Sounds like you need to open it up and take a look. There are two components to the mouse buttons; the electrical button and the mechanical part that depresses the electrical button. It appears something has gotten out of whack with the mechanical button, so use this guide to open it up and take a look.
How to Open Your Logitech MX Master - iFixit Repair Guide
The two mouse buttons on the circuit board are being pointed out by the red arrows.
Look opposite those spots on the top of the cover to find which part presses down on those white bars to click the mouse. Compare the left and right sides and that should let you figure out what's going on with that left button that it's not working right.
You're always welcome to post pictures of what you find once you've got it open; if you do that then we can see too and perhaps may have suggestions on what needs to be done.
Adding images to an existing question - iFixit Repair Guide
Good luck; let us know what you find!
iFixitの画像
ガイド
iFixitでの質問に画像を追加する方法
難易度:
とても簡単
2 - 5 minutes
Logitech MX Masterの画像
ガイド
ロジクールMX Masterの開口方法
難易度:
中レベル
10 - 20 minutes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gilded さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 21
過去 30 日: 60
今までの合計 2,210
