My remote switch isn’t working as it was dropped in water
Water damage can be irreversible. However, if you’re able to open the key and use 90+% isopropyl alcohol and a tooth brush to give the board a good clean. A can of compressed air can help dry the components when you’re done.
Check the battery with a voltmeter to see if you need to replace it as well.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 143
@mohammedatwi always change a battery after liquid immersion!
oldturkey03 さんによる
