メインコンテンツにスキップ
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
Computer crashes to a blank green screen.
I’ve recently built my first pc and for the 1st day it was running great. Yesterday and today hasn’t been the same. After only a few minutes of running the pc will crash in to a blank green screen. Any tips? Anyone else ever have this problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Hi @koithyboi,
What is the make and model number of the motherboard and the GPU card?
Try disconnecting the SSD (HDD?) and check if you can get into BIOS OK with a display.
Have you checked the monitor's working OK i.e. can you view the OSD menus?
さんによる
コメントを追加
1 件の回答
What operating system is it running on?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Was running windows 10 when it started. Upgraded to windows 11 only for it to crash more often
さんによる
It could be a bios issue or corrupted files, maybe you should upgrade your drivers, it could be a monitor issue too
さんによる
コメントを追加
回答を追加する
koithyboi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 111
