メインコンテンツにスキップ
The HP Pavilion 13-s128nr is a touch screen laptop manufactured by HP. It is a convertible PC also known as the HP Pavilion x360.
1回答 すべてを表示
How do I get the back off if the center screw covers are aluminum?
There seem to be screws under these hard center covers because although the keyboard is loos around all edges it won't release. How do you remove these screw covers? I've enclosed a photo
illustrating the rubber feet covering the top screws and the remaining center plates. I appreciate the help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @amberwatkins,
There are two more screws underneath the plastic screw covers in the middle of the back cover.
Try to gently pry them out to access the screws beneath, with either a pry tool (example only) or a suitably sized, flat blade screwdriver. The tool list on p.20 of the guide (see link below) shows all of the tools that are required to complete all of the removal and replacement procedures shown in the guide
Here's the maintenance and service guide taken from this support webpage for the laptop.
Go to the bottom of p.24 to view the pre-requisite steps and then p.25 to view how to remove the keyboard/top cover assembly.
iFixit Opening Toolの画像
製品
iFixit Opening Tool
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Amber Watkins さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 11
今までの合計 115
