メインコンテンツにスキップ
Repair guides for the 2018 version of the Samsung Galaxy A8 Android smartphone released in January 2018. Good features at a good price. Model Number SM-A530F
20回答 すべてを表示
when charging the phone says moisture detected
when i charge my my phone the phone says moisture detected,i don't live in a humid environment and i don't remember dropping my phone on some water,i tried cleaning the usb port but it didn't work. what should i do?
(sorry for my broken english)
Update (06/07/24)
for anyone wandering it is a software issues
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
@senopatib first try this. Turn your phone off. Then connect the charger. See if it does now charge. if you are sure that there is no moisture in the USB port and if you already cleaned it with isopropyl alcohol etc. it is time to replace the port. Of course, on this phone the port is soldered to the logic board which would require some board level soldering. If this is above your level of comfort, consider getting in touch with somebody who does board level repair. Check https://www.youtube.com/watch?v=0ZjDjt6Y... as well before working on it. This video shows you how to replace the port. It's not as easy as the video makes it seem. It'll take some experience to do the soldering.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Senopati B. さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 13
今までの合計 399
