hp spectre x360 not charging or turning on
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント:
Hi @ahmad24812,
What is the full model number of the laptop, as shown on the product info label on the bottom of the laptop?
Have you tried connecting a different, known working, compatible charger to the laptop and check if the laptop showed it was charging?
Use a strong light and a magnifying glass to visually inspect the USB-C charge port to ensure that all the pins are there and that they're not bent, broken or missing.
さんによる
Yes I have 19.6 volts to charge port harness where it plugs in to the motherboard.
さんによる
@techrocker same computer, same issue? What is the full model number of the laptop, as shown on the product info label on the bottom of the laptop?
さんによる
コメントを追加
