メインコンテンツにスキップ
長く待ちわびた人気モデルMac miniの最新モデルです。プロセッサはオプションで3.6 GHz quad-core Intel Core i3、3.0 GHz 6-core Intel Core i5もしくは3.2GHz 6-core Intel Core i7プロセッサから選べます。
20回答 すべてを表示
Conductive glue for PRAM battery?
Dear Community,
the PRAM battery is next to the SSD on the motherboard.
It is attached to the motherboard at two points.
Due to an accident, now only one of these points hold the PRAM battery in place.
I would rather avoid repair service if possible.
As I looked at the attachment, my assumption was that some kind of conductive glue was used to hold the battery in place.
If I used that to reattach it, am I taking a risk?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
In this picture it looks like the PRAM battery is soldered onto the board at two contact points, though I'm not sure about that because I don't have a board to inspect in person. If it is soldered, which it looks like it is, then you would need to resolder the connection to repair it. I'm not aware of any other method of connecting it to the board. Good luck!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Do you think a kind of wire glue, which is said to replace soft soldering, would also do, which is said to be able to make conductive bonds?
さんによる
I'm not sure! I've never tried that. If you are able to do that successfully, let us know :D
さんによる
コメントを追加
回答を追加する
Patrik Nusszer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 135
