I want to fix the speakers
When i open it i dont have access to the speakers
They are covered, i dont know how to open the cover of 2 speakers, there is anyone can help me please ?
@lokmansekkoum if you are referring to the plastic case that is part of the speaker, then those are commonly ultrasonic welded shut. You could try to separate them with a scalpel or similar cutting tool, then proceed with your repair. Use an adhesive or plastic welding process for DIY'er to close it back up. It is best if you show us the casing etc. so we can see what you see and hopefully guide you correctly. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 59
