メインコンテンツにスキップ
2.4GHz, 2.7GHzもしくは2.8GHz クアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大 3.8GHz) with 6MB 共有 L3 キャッシュ。
274回答 すべてを表示
HDMI port not outputting. even when screen is disconnected
Hey guys,
I got a 2.4 GHz Retina 15" Early 2013 with a dead backlight. I disconnected the display and I'm trying to output through HDMI but the port itself does not work. I have a thunderbolt to HDMI adapter and it does work as it does output, but overtime it'll disconnect and I have to shutdown the laptop and power it back on for it to work again.
If anyone has a solution for this, please help me out. Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It sounds like the IO board may be failing. Check out this guide for instructions on how to replace it. If you think the adaptor you're using could be faulty, then I'd recommend trying to borrow a separate adaptor for testing, or taking the device into a repair store for testing. It might also be a good idea to inspect the interior of the device for other signs of damage—something like this could technically be caused by a fault on the main logic board as well. Good luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Marcus Spano さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 18
