Joystick only going up and down
my left joystick came off and I took apart the device and now its only going up and down does not go left and right.
my brand new rog ally that i just received from amazon have left joystick going only up and down...many people have same problem.. return the device. i will do the same today. nothing we can do its defect
このアンサーは役に立ちましたか?
Mine has the same issue and I finished all patches by second release day. I was playing Diablo IV perfectly fine and then on day 5 it only registers the up/down movement even in windows explorer. I also feel this is a hardware related issue because it was running perfectly for several days.
このアンサーは役に立ちましたか?
Guys I hope you come to this answer kind of fast to save yourself time. I took apart my stick with the same issue. There is a fix for some, but it's not worth the effort IMO. It's a very weak plastic and the metal clamp at the bottom if bent too hard will break instantly. Better to either replace the stick from the beginning or the whole device if you have warranty. Don't try to fix the stick. Mine ended up being broken on the inside anyways, wasn't worth the effort to open up the stick.
I ordered a looks like it had a part the same joy stick the windows gpd 3 has mine actually came off because it fell out it can’t exchange it now since I opened it
このアンサーは役に立ちましたか?
my asus rog ally was working perfectly for a couple weeks. and then it started where the left stick only moved up and down. so I went into the bios and I saw the mouse cursor kept moving to the right. and this is because of the left stick! if I pushed on the left stick to the left, it would stop the mouse cursor but it couldn't move it back to the left. once the cursor gets to the right edge of the screen, it's stuck and you can only move up and down. if you switch to a different tab or page in the bios, you'll see the hand cursor keep moving to the right.
このアンサーは役に立ちましたか?
I know a place to get hall joystick with turorial.
このアンサーは役に立ちましたか?
Hey, its an Hardware Issue. I replace my sticks with Hall effect sticks, works fine and no problems anymore. I dont know why its only the left Stick with this 'up and down'-issue...
このアンサーは役に立ちましたか?
過去 24時間: 31
過去 7 日: 139
過去 30 日: 619
今までの合計 6,843
could it be possible you misaligned a shield around/near the joystick?
timtom77 さんによる
Same issue but I have not taken mine apart. They screwed up in production. I have to go return mine.
hagedorn2011 さんによる
