メインコンテンツにスキップ
The Nokia N8 is the first device to run on the Symbian^3 mobile operating system and Nokia's flagship device of 2010.
20回答 すべてを表示
The phone is not turning on need to install new software
The phone is not turning on stacks on Black screen need to install new software
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi:
I'm not sure I understand your question correctly, but perhaps the following may help
in the event that your phone will not charge or otherwise operate. It's possible software
is not the issue.
Cellphones require a good battery to turn on and run successfully. I assume you have replaced
the battery from the original 2010 one. Does it charge in the phone? If not:
I recently received a cellphone stuck in an endless startup loop. No attempt by me to do a reset or anything
else succeeded.
I examined the phone battery. The phone is relatively new (2019) and the battery was
not bulged or damaged. I recalled reading that cell batteries have a protection circuit built
into them. The SD card in my phone showed evidence of static shock damage (I was eventually able to recover and reformat it).
So I suspect some kind of shock 'tripped' the battery protection circuit.
I remembered reading it is possible to take a usb wall charger and 'shock' the battery back to life, after which
the battery can again be recharged inside your phone.
Here's a sample YouTube video showing the process: https://www.youtube.com/watch?v=5Oz0liBM...
(I'm sure there are many other videos--this is just the first to come up.)
If you or anyone decides to try this method, act with care since you alone are responsible for any damage or injury that could conceivably result.
BTW, I followed the procedure in the video and it worked for me. I now have a nice backup cellphone instead of a brick.
Good luck in any case!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Abhay Kumar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 82
