メインコンテンツにスキップ
A radio device used to remotely listen for sounds made by an infant.
74回答 すべてを表示
Motorola Lux 85 Connect parent unit not connecting to baby unit
Hi, my Motorola lux 85 connect parent unit (monitor) isn't working. It beeps with a red camera logo on a black screen but no video as it's obviously disconnected from the baby unit.
The baby unit (camera) works as I can see my baby via mobile app over wifi. There could still be an issue with the baby unit not sending out a signal to the parent unit.
I have tried resetting both units, checked the internet connection and followed all other troubleshooting I could find online but it's still not working.  I purchased the unit in 2021 so it's out of warranty. I'd really like to try fixing it, I have limited experience of repairing electronics.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @electrorouge,
Some troubleshooting steps to do to try and isolate what's happening
Don't know the device but is the red light on a normal condition when it is connected or is it a different colour e.g. red for standby, green for on/connected etc?
If it is normally only red when on and working, then looking at the user manual there's also audio capability between the two units. so can you hear anything at the parent unit end coming from the baby unit or perhaps at the baby unit end when you talk into the parent unit?
If you have a Windows PC (laptop or desktop) that has WiFi capability, download, install and run this free WiFi sniffer program and check if you can detect the WiFi network signal from the parent unit.
Most probably there won't be a network name associated with the unit as it will be hidden but the network will still show up in the program.
If it does detect hidden networks, turn off the parent unit (ensure that the baby unit was turned off beforehand so as to not confuse the issue) and see if it is no longer being detected by the program. To prove it is the one turn the parent unit back on again.
If it is being detected then the WiFi is working but for some reason the video signal isn't.
If it isn't being detected at all then the WiFi isn't working
Maybe a start to find out what's happening.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Electro Rouge さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 17
過去 30 日: 75
今までの合計 427
