メインコンテンツにスキップ
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
171回答 すべてを表示
Blank screen/No signal
Built a PC. Everything shows it is running. The screen is npt connecting to anything. I have tried different monitors and different setups, different hard drives. No BiOS or anything comes up.
ASUS Prime Z590-P WiFi motherboard
Intel Core i7 11700F processor
GTX PCIe 730 Graphics card
CORSAIR DDR4 16GB RAM
I have reset CMOS. I have taken everything out.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @familyfun37946,
Is the 16GB memory, 2 modules i.e. 2 x 8GB or one 16GB module? Depending on number of memory modules have you installed them as per p.1-5 of the user manual?
The PC may not be passing POST (power on self test)
Try connecting a system speaker (example only) to the speaker pins on the System Panel connector on the motherboard (see p.1-20 of the manual for location of header and speaker pins) and check for any beep error codes (see beep code table on p.2-19).
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
They are two different sticks. They are seated in properly and everything. They even light up.
I will try the speaker test. It did not come with one, so I will have to get one. Thanks!
さんによる
コメントを追加
回答を追加する
Dreki さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 41
