メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
Proper cleaning of the logic board for iPhone 6 Plus
Good Afternoon,
I'm reassembling my iPhone 6 Plus and as I'm about to put in my logic board I thought I should clean it like I have all other parts for this rebuild. What is the safest way to clean any dirt or dust that may be stuck to it and are there any areas to the logic board that should not be touched or wiped in any way that are possibly too delicate? I want to make sure that I don't damage anything that wasn't damaged before especially due to something that was because of my lack of knowledge and for which I could have avoided.
Thanks Much for any advice on this. Your time is greatly appreciated!
-Brittney
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I use in my work 99% isopropyl alcohol and tooth brush, better is some soft brush or some paining brush. Alcohol will not damage any component on the main board. Only be carefull with cameras and microphones.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Okay, Great! Thanks that helps me a lot. How much of the 99% isopropyl alcohol should I allow to cover the logic board when brushing away dirt with a soft brush? Is there a too much or a too little? In other words where would be a good place to apply this technique between a very fine mist of alcohol over the board and then lightly brushing away any dirt to just placing it in a small bowl filled with the alcohol to soak and brush from inside the bowl?
さんによる
コメントを追加
回答を追加する
Missbritt486 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 44
