メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xbox Originalは、Microsoft初の広く普及したビデオゲームシステムです。上部と前面に「XBOX」のロゴが入った、識別しやすい黒いケースが特徴です。一般的な工具で簡単に修理できます。
Xbox (1.0) Burnt out Resistor on PSU Board.
Hello, I'm new to electronic so apologies if this is a foolish question. I have a burnt out Resistor on my power supply as seen here.
画像
画像
Looking at another Xbox I believe the bands on the resistor are Yellow, Brown, Orange. Indicating a 41 kΩ. The problem is I don't know the wattage or the tolerance. Does any one know what I would need to buy to replace this burnt out resistor to prevent it from burning out again? Thanks for taking the time to read and reply.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
I'd love to know if the original issue was resolved by replacing this resistor. I'm also curious if replacing the other components that appear to be surrounded by burnt board ended up being necessary also. Specifically, that ceramic capacitor and additional resistor to the right of R13, as well as whatever component is to the right of that but hidden a bit.
さんによる
コメントを追加
1 件の回答
ベストアンサー
@samdonald I suggest that first you remove the complete power supply board. Then remove the resistor. Measure it to verify that it is a 41kΩ when it is out of circuit. Clean the board of any burned residue with some cotton swabs and isopropyl alcohol. Inspect the other components closely (focus on the diodes in that area) and check the bottom side. There are components as well that may get damaged. For the Through-the -hole resistors the size of an axial resistor is relative to its power rating. Measure the physical length of the resistor body. Then check this chart
画像
from here for the wattage.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Okay, i'll have to measure it tomorrow if I can find it. It's my understanding (after looking over some google forums) that I can buy a larger resistor with a higher Watt and that will be okay.
Is this something I should look at? Would A higher Watt provide more protection from the load that doomed the last one?
And on another note I'm just color blind. The bands go Yellow, Brown, Orange then Gold meaning there is a tolerance of + and - 5%
edit* Just so people know the specs if some one else comes looking
Resistor Place on board: R13
Resistor Bands: Yellow, Brown, Orange, Gold (41k +-5%)
Dimensions: About 7 MM (1/4 Watts)
Thanks for the help. I'll make sure to have ham this thanksgiving.
さんによる
@samdonald that is correct. With the color bands you describe, the resistor is a 41 k Ohms 5%
Sure you can go higher on the wattage but no it does not provide more protection. It just means that the resistor can use more power. There is a reason why it "blew up". It could be a resistor failure, or a short to ground in the circuitry. That will be difficult to repair since I haven't seen any schematics for the PSU
さんによる
I think there is some schematics floating on the orginalXbox reddit, but it's set to private. I've been trying to get in there over the last week, but I think me being brand new to reddit is seen as a red flag.
In any case I'll spend a couple bucks on a resistor if that doesn't work I can always just buy a PSU online, or better yet another broken xbox to add to my tower of doom! Thanks again for the help.
さんによる
@samdonald yeah, looks like it's set to private and you'll have to get permission. PSU's for it are inexpernsive and will definitely be an option.
さんによる
コメントを追加
回答を追加する
TheGreyKeyzard さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 32
今までの合計 1,224
