Why is my headset not charging but can play when connected via cable
JBL Everest Elite 750 N-C won’t get charged. Where can I get it repaired in Saudi Arabia or South Africa?
@thabanikhanyile that would be a bit above the scope of what we are trying to do here. We generally do not make recommendations to repairers or suppliers unless they are known to all of us on here. Answers to questions like this are almost always subjective and can lead to a lot of confusion or Spam. Since you are in this region, do an online search or ask other repairers in that region for recommendations.
Here, we try to empower YOU to repair your own device. To save your hard earned money by repairing it yourself. Like in the case of your headphones. You've said they play and work when connect via wire but do not charge. The very first thing you would want to do in case like this is to:
If you use a somewhat methodical way to troubleshoot, you can ix it yourself.
Use something like this video to replace your battery. It is a different model but essentially it is the same way.
While you work on your headphones, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 109
