メインコンテンツにスキップ
The Razer Blade 15 (Base Model, 2020) Model Numbers: RZ09-0328 The 2020 Razer Blade 15 Base Model is a high-performance gaming laptop featuring a 10th Gen Intel Core i7-10750H processor, 16GB of RAM, a 144Hz 15.6" Full HD display, and an NVIDIA GeForce GTX 1660 Ti GPU. Designed for smooth gameplay and creative workloads, it’s a sleek, powerful machine built for serious users.
Where to find replacement feet/parts?
Hi the feet of my Razer Blade 2020 (base) are pretty worn out and have started to come off as well. Does anyone know where to find the part? I've looked underneath the rubber strip and there seems to be some notches/clips, I doubt normal sticky feet with have a good hold.
I'd also like to replace one of the plastic covers underneath the hinge as that seems to have cracked and makes a small creaking sound when opening/closing the lid.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
I always recommend (as crazy as it sounds) going to EBAY and typing the exact model for your laptop and any part numbers for the pieces you need if you can find them. Working at a repair shop that’s the easiest way to get a good outer lcd cover replacement for a good price that matches.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi thanks for the reply! Do you have any specific shops to recommend going to/messaging to see if they can accommodate my request? I'm not seeing any feet or bottom covers with my model RZ09-0328x. Unless I missed it!
さんによる
コメントを追加
@shiroytaro I've bought feet for another computer from here before. I would call them and see what they can tell you about replacements for your Razer
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi thanks for the reply! I've actually already ordered from this website (I asked them to put up the 2020 listing!), the feet they sell seem high enough quality but they are completely flat. The Razer Blade's base cover has 2 notches sticking out for the feet to connect to, interfering with the adhesion.
さんによる
コメントを追加
回答を追加する
Anthony Wong さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 31
今までの合計 482
