S20 FE have incomplete connection and the charging cable is loose,
Recently have a issue with my FE20 phone while charging it has incomplete connections and the cable is very loose
Hello Bob, I'd try using a different cable first. If the connection still appears to be loose, the charging dock daughter board can be replaced. If you have a model G781V/B it's a relatively simple fix that doesn't require any soldering. The port is replaced as a circuit board assembly. Either way, you may want to seek a repair professional to have the work done.
このアンサーは役に立ちましたか?
Unfortunately, iFixit doesn't have a guide for your phone, but there's a Spanish site called Nadie Me Llama Gallina (Nobody Calls Me Chicken) that does.
https://www.nadiemellamagallina.com/en/m...
With those instructions, it is straight-forward to do the repair yourself.
Thanks Jerry. I didn't realize that. I'll make one for iFixit tomorrow. I didn't realize there wasn't one on here.
Loads of videos on YouTube
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 467
1件のコメント
Hi Bob! Have you tried using a different cable?
Laurel Leeds さんによる
