Why my car overheats
Nissan march 2004 model overheats at 100km, why?
Hello there,
Without more information all I can really do is guess.
A car can overheat for a few different reasons but the main reasons I have seen are the thermostat is stuck/seized or the coolant needs to be replaced because it is dirty for some reason.
This can lead into other causes of why the coolant is dirty but those are two things it could potentially be.
このアンサーは役に立ちましたか?
To add to Lee's possibilities, the coolant level could just be low.
In any event, at higher speeds more cooling is required as the engine is working much harder than it would be at a lower speed, and it sounds like your cooling system can't keep up for some reason.
I ran into a similar situation with my wife's Mazda where it would overheat on highway driving; in that case it turned out the radiator was partially blocked and couldn't provide the full amount of cooling needed. Replacing the radiator turned out to be the fix in that case.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 20
