メインコンテンツにスキップ
Samsung Galaxy Note 20 Ultra 5Gアンドロイドスマートフォンの修理ならびに解体情報です。2020年8月発売。
46回答 すべてを表示
small help for my motherboard note 20 samsung
my phone have problem black screen and touch work
iam sure the problem is backlight ic
but i dont where place on my motherboard can anybody help me
that some picture:
plate the screen:
https://guide-images.cdn.ifixit.com/igi/...
plate motherboard and some extra plate:
i just what know the place backlight ic to fix it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @madisonjfry
I don't think that there is a separate backlight IC as such.
According to the specifications the phone has an amoled display.
Amoled displays are different to LCD displays in that the individual pixels produce their own light so separate backlighting is not necessary. The pixels are either turned on or off.
Here's a link that describes it better than I can, that may help
Update (06/06/23)
Hi @madisonjfry ,
Perhaps check if the display cable is securely connected first.
Here's the no display troubleshooting flowchart from the service manual that may help to know whether it's a display problem or a systemboard problem.
Unfortunately the manual is not quite complete as it doesn't show the location of all the components mentioned as test points. -
I only found one i.e. U10001. Here's an image of the board that it's on to show its exact location on that board.
(click on images)
Update (06/06/23)
Hi @madisonjfry
Here are the Samsung part numbers for the complete display modules for the model. It seems that there is more than one part number for the same part as searching for any of the part numbers for a variant gives the same result. Search online using the part number only to find suppliers that suit you best
Samsung Galaxy Note 20 Ultra (SM-N985F SM-N986F)
Display unit complete mystic white GH82-23622C GH82-23597C GH82-23621C GH82-23511C GH82-23599C GH82-23596C
Display unit complete mystic black GH82-23622A GH82-23597A GH82-23621A GH82-23511A GH82-23599A GH82-23596A
Display unit complete mystic bronze GH82-23622D GH82-23597D GH82-23621D GH82-23511D GH82-23599D GH82-23596D
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
so i must replace full screen? to fix this problem?
さんによる
yes all is fine connected
when the display take black i on bed watch youtube then go to black and the sound still on ( but phone very hot before screen do to black)
so i think is no problem with cable
さんによる
@madisonjfry
The display is not cheap to replace so I don't know what the best option for you is.
Getting hot is not good but it could be that the display is the cause of this problem or maybe not.
Perhaps it may be better to take it to a reputable , professional authorized Samsung repairer and get it checked out. They may have compatible displays available that they can temporarily connect to find out. Also they can test the board to see if it is the problem.
さんによる
any idea from where can buy screen good quality?
i check alixprees all bad quality
さんによる
コメントを追加
回答を追加する
Madison J Fry さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 12
今までの合計 162
