メインコンテンツにスキップ
The Samsung Galaxy A10s is an Android smartphone developed by Samsung Electronics, and was released in March of 2019.
20回答 すべてを表示
Why my phone is not charging?
My phone is not charging
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
@habeshanprince a bad battery is always a possibility. Of course, make sure you have a good charger and charging cable. Make sure that it supplies the proper voltage and has not bend, broken or corroded connector. Also check the charging port for debris, corrosion. If that still won't work, replacing the charging connector would be next on my list. Guides are available at sites like this
While you work on your battery and charging connector, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Habeshan Prince さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 154
