メインコンテンツにスキップ
Western Digitalによる外付けハードドライブのモデル。ハードバウンドの本に倣ったスタイルです。 EssentialからPremium、WorldEditionまでさまざまなエディションで利用できます。
31回答 すべてを表示
My WD My Book Essentialbook is Not Getting power
I accidentally knocked this sucker off my desktop and the power adapter caught the weight. It was bent a little so I hastily began tryin to pry the case off with hopes of putting the hd in my desktop to recover the info. I haven't been able to make that work so I tried to solder the broken power jack on the case. That didn't get me power either so nOw I'm wondering what I can do to retrieve my data.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
First, I'd consider buying another power supply and try that now if it's not more then the enclosures I listed for a desktop harddrive
here is a disassembly video
You likely damaged traces on the board in the enclosure if you tried a new power supply, so your only option now is HDD enclosures
take this drive apart and find out if it's sata or ide
a SATA connection
http://en.wikipedia.org/wiki/File:SATA_P...
IDE
http://en.wikipedia.org/wiki/File:Ata_20...
check your drive(s) in the MyBook enclosure and compare them to those pics
Next, pick your enclosure(note I picked ones I feel are well priced and have good star ratings already, pick your own if you want to)
SATA
IDE
*note I am NOT a big fan of eBay personally for anything but junk computers with other issues besides mine to get parts from, so that's why i linked to amazon*
change the enclosure and you'll be able to reuse the drive too
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Nickelfitz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 3,930
