メインコンテンツにスキップ
Fitbit Charge 5は、2021年8月25日に発売されたフィットネストラッカーです。ECGセンサー、手首の汗を計測するEDAセンサー、カラー付きAMOLEDディスプレイが追加されています。
Fitbit wont charge but will vibrate
Hi my fitbit charge 5 said critically low battery. But when i tried to charge it would not charge. I changed the charger and still no go. The green lights in back will not even light up, but it does vibrate when the charger is put on and off. I tried resetting, cleaning the contacts etc. It also will not sync.
What else can I do.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
The "recommended" solution seems to be to
(1) Attach your charge cable to your pc USB port
(2) put your fitbit to charge
(3) Tap on the screen three (3) times within 1.5 seconds
this is supposed to "reset" the fitbit and "solve" the problem.
It worked once for me but now it doesn't anymore.
Fitbit solves the obsolesence problem by breaking down and becoming e-waste well before. Pathetic build quality and caveat emptor anyone who is taken in by them.
さんによる
コメントを追加
3件の回答
最も参考になった回答
I had the same problem. The battery finally died out. My watch just passed the warranty for two months. Fitbit offered me 30% to buy a new one. Fitbit doesn’t take responsibility for their low reliability product
このアンサーは役に立ちましたか?
スコア 6
1件のコメント:
Same here bought 17 months ago. Battery has died.
May change to another maker
さんによる
コメントを追加
Not started my Fitbit charge 5
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have fitbit charge 6, it does not start. What should I do?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Cover the basics:
1) make sure the USB charging port you're using works with other devices.
2) make sure the contacts on your fitbit and charging cable are clean and properly aligned
3) press the button on your charging cable to reboot your fitbit
さんによる
コメントを追加
回答を追加する
Mae Everett さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 15
過去 30 日: 58
今までの合計 1,740
