Is there any way to check and repair the keyboard connector?
My type cover has stopped working. I tried many things but to no avail.
I have the same problem. To debug I have bought another keyboard (second hand) and it seems either both are broken or that my connector is broken.
The above tests lead me to think it is a connector related problem...
このアンサーは役に立ちましたか?
I have tear down my Surface Pro 4.
The connector appears to be in good condition, no issues on the flex cable connector, no issues in the motherboard pins that connect to it, no issues in the back of the flex cable (there seems to be a ground connection to the case).
Connector pins show either good grounding, 3,26v (~3.3v) or 4.96v (~5v) so it seems all is good in the connector side but I still get no light on the keyboard cover nor any sign of it working in the UEFI menu. Now I only have one cover available for testing...
After a full teardown, that by the way is not fun at all, I cannot find anything hardware related to this not working... :/
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 6
過去 30 日: 29
今までの合計 436
