メインコンテンツにスキップ
Dell XPS 15 7590 Laptop with OLED or touch panel.
1回答 すべてを表示
Laptop won't wake/power on without power adapter connected.
I got a new battery from iFixit matching the model number of the stock battery installed in my laptop (6GTPY, 97Wh), installed it, and calibrated it. I then noticed that within 2 days the health dropped by >10%, and sometimes the laptop wouldn't be able to wake from sleep without the power cord connected. After turning it on I could see that the battery had plenty of charge. I contacted support and they sent a new battery but this one has the same issue with turning on the laptop. Since this has happened twice now I am unsure if it's a faulty battery and was wondering if there was anything I could do to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
what are your current battery power settings on the computer?
さんによる
I've basically disabled sleep as this issue seemed to occur more often with sleep. So I have all relevant settings for sleep set to never and use hibernate instead. Even for hibernate I have it hibernate after 10 minutes. The Modern Standby causing excess battery drain was also a factor and I switched over to hibernate before getting the new battery to avoid modern standby.
さんによる
コメントを追加
1 件の回答
Hi @johnsalt
If you haven't already done so, try reinstalling the battery drivers.
Press Windows key + R to open a Run command box.
Type devmgmt.msc and press Enter.
In Device Manager, click on the Batteries categories to expand the list.
Right click on Microsoft ACPI-Complaint Control Method Battery.
Click on Uninstall.
Restart the laptop and check.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John Salt さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 185
