What size star tip does the front break caliper take
What size star bolt is the front calipers mounted with?
@scottturne66536 those are Torx T55. Those are a bear to take off, so you want to make sure that you use a cheater bar as well. You do not need to take those off, if you just want to change your brake pads etc. For that, you just remove the two 18mm bolts to remove the caliper bracket. Just saying....:-)
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 33
過去 30 日: 171
今までの合計 710
