Why does my screen have a green tint
When I turn my Wii on it has a distinct green/yellow tint to the screen. It’s painfully old and was wondering if there is a way to fix it or is it time to buy a new one. Thanks for any advice.
If you are using component cables (red green blue) make sure you inserted the correct color into the correct corresponding colored jack.
If you are using a Wii2hdmi converter, maybe it's faulty. If you aren't using one maybe it's time to get one, they are fairly cheap.
If you are using composite cables, try using a different known working cable.
In my experience this "usually" happens because the person is using component cables and plugged the wrong color plug into the wrong jack. Good luck!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 14
過去 30 日: 66
今までの合計 942
