@moniquegoings what kind of noise? Sounds like ? Where in general do you think that noise comes from (side, rear, front, bottom)? Any check engine lights on? Anything unusual when you drive your Rogue (other than the noise)? What exact year is your Rogue?
That is a fairly vague description of the problem. If it goes away quickly, it may be the exhaust system. That expands quite a bit as it heats up and that expansion may provide clearance that the system doesn't have when it cool.
oldturkey03 さんによる
Pressing gas pedal when start to drive. I already had my catalytic converter replace. Rumbling sound in the front.
Monique Goings さんによる
It a Rogue 2015
@moniquegoings do you hear that noise only when your Rogue moves or is the noise there when you are stopped and the engine running?
oldturkey03 さんによる
