Why is my pc not receiving power?
Why can’t my pc start after I plug it in power?
Confirm that the power outlet is functioning correctly. Try plugging another device into the same outlet to see if it receives power. If the outlet is not providing power, try using a different outlet https://thebgmiapk.com/ or consider testing the original outlet with a different device.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 25
@alextemba does your computer show any sign of life? Any LED on? Have you checked your charger? Is the output of the charger ok? what have you checked?
oldturkey03 さんによる
