メインコンテンツにスキップ
2007年にフィリップス社より発売された電動歯ブラシ。効果的に歯をクリーニングするための5つのモデルに分かれています。
6回答 すべてを表示
Beeping, one long, two short
My trusty Sonicare has started beeping in a repeating pattern while charging. It still works, but only occasionally. Is this fixable or do I need to buy a new one? It is by far the best toothbrush I have ever had, so I don't want to just discard it without attempting a fix or knowing I need a new one.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
Mine only works for about 2 seconds and stops
さんによる
コメントを追加
2件の回答
最も参考になった回答
Try this fix first. Hold down the SILVER button for 5 seconds while the toothbrush is on the charging base. If the fix works, it will fix the problem immediately like magic.
If that doesn't work, try this:
1) remove the brush head.
2) use a screwdriver in the base and turn 1/4 turn
3) push out assembly from the top
4) dry the inside of the base handle. allow it to air dry
5) allow the switch to air dry
6) reassemble
このアンサーは役に立ちましたか?
スコア 3
8 件のコメント:
my sonicare doesn't have a silver button, only a green one. And no screwdriver has been able to turn the base 1/4 turn. Any other ideas?
さんによる
Mine also does not have a silver button. I think it depends on the model. I just held down the power button while the brush was on the charging base, per Hayden's instructions above. It responded with a series of vibration signals, then the beeping series stopped "like magic." So far, so good.
さんによる
None of the above works
さんによる
None of the suggestions work. Tge beeping is driving me crazy.
さんによる
None of the suggestions work. The beeping is driving me crazy.
さんによる
3件以上のコメントを表示
コメントを追加
Had the same issue. From what I can tell, it was telling me the toothbrush was still on while it was charging. (The battery died mid-brush.) I turned it off while on the base (don’t know if that matters) and the beeping and flashing lights stopped. Hope this helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Don H Smith さん、ありがとうございました!
統計データ:
過去 24時間: 49
過去 7 日: 376
過去 30 日: 1,423
今までの合計 33,807
